Is there any way possible to add a new Inbound rule so it comes to the top instead of going to the bottom.
Calvin1723
Gold Partner
Hi Calvin,
When you add new ones they go to the bottom of the list, you can select one and reorganize it using the move up / down buttons. I hope this is what you were looking for.
13908
Thanks John, i have more than 1000 rules and it is impossible to manually move it up.
Tedious yes. Impossible? I don't think so. But the other option is to export, edit, nuke, import. Take a backup first :)
Reactions: craigreilly
haha, of course, it is possible. Will try exporitng and importing.
Hope that works for you. I feel for you with 1000 inbound rules. Maybe a CFD would cover that?
Is there a document to follow if i want to execute the inbound rules via the CFD?
I am curious, why so many rules ? what is your call scenario ?
3K8iMGWviZ
