Is Virtuozzo 7 supported as a hypervisor?
SteveITS
3CX MVP
Hi 3CX,
https://www.3cx.com/docs/recommended-hardware-specifications-for-3cx/#h.zeoyi5w0lmgf says KVM is supported. Per https://www.3cx.com/community/threads/debian-install-3cx.73274/, is Virtuozzo 7's KVM supported or not?
If not, can the requirements list be updated to reflect which types of KVM are compatible?
For reference our Virtuozzo 7 has installed:
Arch : x86_64
Version : 4.5.0
Release : 23.vz7.12.1
Repo : installed
From repo : virtuozzo-updates
Summary : Server side daemon & driver required to run KVM guests
URL : https://libvirt.org/
License : LGPLv2+
Description : Server side daemon and driver required to manage the virtualization
: capabilities of the KVM hypervisor
Arch : x86_64
Epoch : 10
Version : 2.12.0
Release : 33.7.8.vz7.6
Repo : installed
From repo : virtuozzo-os
Summary : QEMU common files needed by all QEMU targets
URL : http://www.qemu.org/
License : GPLv2 and GPLv2+ and CC-BY
Description : qemu-kvm is an open source virtualizer that provides hardware emulation for
: the KVM hypervisor.
: This package provides documentation and auxiliary programs used with qemu-kvm.
Arch : x86_64
Epoch : 10
Version : 2.12.0
Repo : installed
Summary : KVM debugging and diagnostics tools
Description : This package contains some diagnostics and debugging tools for KVM, such as kvm_stat.
Arch : x86_64
Epoch : 10
Version : 2.12.0
Repo : installed
Summary : QEMU is a machine emulator and virtualizer
Description : qemu-kvm-vz is an open source virtualizer that provides hardware
: emulation for the KVM hypervisor. qemu-kvm-vz acts as a virtual
: machine monitor together with the KVM kernel modules, and emulates the
: hardware for a full system such as a PC and its associated peripherals.
Thanks,
Hi @3cx, @NickD_3CX and @JohnS_3CX, sorry to bug you personally but do you happen to know the answer? (whether all varieties of KVM are supported)
Thanks,
I asked 3CX's partner team and they said to keep waiting until someone answers in this thread, so I'm bumping the thread.
@StefanW Do you know who at 3CX would know if some types of KVM are not supported?
No, it is not supported as it abstract the network layer beyond what KVM/VMware etc are doing (container-based abstract layer). Supported are native use of
using 3CX ISO:
Vmware ESXi
Microsoft Hyper-V (follow guides for setup instructions)
KVM native
Citrix Xen
using Marketplace or PBXexpress:
Amazone EC2/LightSail
Google Cloud (GCP)
Microsoft Azure
OVH
Thanks for your reply. Just to clarify one point though you mentioned containers and we're using VMs. I am a bit surprised as we've had no issues in the past year on any installation.
Wecare_ITA
