Issue Installing on Raspberry Pi - Unsupported Hardware or something else ??
RAW
Hello
Have tried installing via the documentation
https://www.3cx.com/docs/installing-pbx-raspberry-pi/
And I keep getting to 98% on the installer and then fails with
dpkg: error processing package 3cxpbx (--configure):
subprocess installed post-installation script returned error exit status 139
Setting up nginx (1.10.3-1+deb9u3) ...
Processing triggers for libc-bin (2.24-11+deb9u4) ...
Errors were encountered while processing:
3cxpbx
E: Sub-process /usr/bin/dpkg returned an error code (1)
Tried uninstalling and re-installing and get same error
These are the PI Details
cat /etc/debian_version
9.11
uname -a
Linux pi-voip 4.19.66+ #1253 Thu Aug 15 11:37:30 BST 2019 armv6l GNU/Linux
processor : 0
model name : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 697.95
Features : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2835
Revision : 000e
Serial :
Any help appreciated, TIA
Robert
Which Raspberry Pi model is this?
Hardware : BCM2835
I guess this is the Broadcom chip used in the Raspberry Pi Model A, B, B+, the Compute Module, and the Raspberry Pi Zero... and these models are not supported by 3CX.
Edit: to be more specific... this is a:
Raspberry Pi Model B Plus Rev 1.2
Reactions: RAW
Hardware : BCM2835
Which model of Pi do I need to run the 3CX software in Premise please
Your English is excellent BTW and thank-you
That model is the Raspberry Pi 1 and it is neither supported nor tested (and less powerful to handle the task).
Switch to a 3B+ and you should be able to install without any issues.
business@brightwaylogisti
