Issue with Twilio SMS
brenrich101
Hi guys,
I did have this set up on a previous version on another system, working well. Now I want to try and use it again but can only get half way.
V18 U5, and want to use the SMS functionality with Twilio (open to other suggestions, but it appears to be tricky getting this working in the UK). I have set the SIP trunk up, where the messages go, and enabled chat and SMS for the user.
I can text from my mobile to the Twilio number, and it comes through on 3CX fine, working as it should (Twilio reports an error but I can ignore that). I can't reply from 3CX though, I just get the little red cross under the message.
In the 3CX event log, it says something about an incorrect username. At least that much is helpful, but I've tried every API key and account SID I have, along with any possible password, and nothing seems to work.
Does anyone know what credentials I should be using, and where I correctly enter them please? Is it the Authentication section on the SIP Trunk - if so is it just incoming/outgoing/account based? Our partner doesn't want to help, Twilio doesn't want to help. At a loss, but I figured someone has done it before successfully surely?! :)
Thanks in anticipation!
Brendan
Hi @brenrich101,
Please note that since Twilio is IP based, it should not require a username and password in order to authenticate. In SMS configuration you only need the Account SID and the Auth Token from your account info in Twilio.
As a first step, ensure that no changes were made in the default template of Twilio upon configuration and in case changes were made, delete the trunk and recreate it without making any changes, except those that are required.
Also, find the guides regarding SMS and Twilio SMS configuration and ensure that you followed all the steps. Also read carefully the 'To Configure a Number for SMS' section of the guide that specifies what is needed in order for the SMS number to work properly:
• https://www.3cx.com/docs/manual/sms-text/
• https://www.3cx.com/docs/sip-trunk/twilio/
mbar
