Solved Issues with 3cx Showing Private number on external calls
BillyEGG
Hi folks
I'm having an issue after setting up a digital receptionist IVR.
My number when calling out is showing as Private Number Even though i can dial the number fine.
The provider is SIPGATE and All ports are set up Outgoing calls are working but just not showing my main trunk number.
Thanks in advance
Could you check in what format the Main Trunk Number is written in?
It should be in format e.g. 4420300000000
Also if the Extension you are dialing from has an Outbound Caller ID set, make sure that is also in the same format.
Hi there just checked and it seems to be working again.
I believe it was the providers fault when we switched to the New IVR.
Thanks for the help
Reactions: NickD_3CX
Glad we could help!
lastshadow
