Issues with Call Forwarding
aamarpay
I have a SIP (+8809643XXXYYY).
I have a Ring Group (Ext. 600). I have two Users (Ext. 602, 603). I have added the users to Ring Group.
My SIP's default route is to ring the RG (600). RG is set to prioritized hunt.
I want the calls to the SIP are directed forwarded to users mobile number (External Number). I have set user's mobile number there in his profile. Also, from Call Forwarding, if not registered, calls are forwarded to Mobile Number with Rebound Enabled/Disabled neither works. It shows in log Terminated by Rule.
If I set the SIP's Default Route to Ext 603, then it rings my mobile correctly but sounds "You got a call from 018xxxxxxxx. If you want to join, press 1". This was not there earlier in previous version.
This was all working in the earlier version, the new version is making the issues.
Carlos - EC Mates
