Solved IVR (MakeCall) busy
Maryan Petryshyn
Forum User
Hello.
When I call from phonebook in the webclient (ver.15.5) my phone calls me, but don't call client number. I understand that I need to change some settings but don't know which.
Thanks.
Can you provide a bit more of a detailed explanation of the problem. I'm not really clear as to what the issue is.
Hello @Maryan Petryshyn
Do you have an unsupported device connected to the web client which results in "Make Call"?
If so are you calling numbers with "+"?
Hello.
Thanks for all. Problem solved. The bug was with wrong outgoing calls plan.
Glad to see the issue has been resolved and thank you for updating the thread.
apbGroup
