IVR Not found on 127.0.0.1:5483
fantawttw
Hope someone can help me. I have a fresh install of 3cx free edition and as soon as I bring up the status screen I receive the following status messages
10:52:29.562 ??: from 'maxdata:0/MediaServer':*** Connecting to [127.0.0.1:5483] ***
10:52:28.468 ??: from 'maxdata:0/MediaServer':IVR not found on 127.0.0.1:5483
10:52:27.484 ??: from 'maxdata:0/MediaServer':*** Connecting to [127.0.0.1:5483] ***
10:52:26.484 ??: from 'maxdata:0/MediaServer':IVR not found on 127.0.0.1:5483
10:52:25.484 ??: from 'maxdata:0/MediaServer':*** Connecting to [127.0.0.1:5483] ***
I have looked in the log files and this contains the following.
2007/04/03 >>
10:41:21.843|0e38|.\3CXIvrService.cpp(427): IvrService, main(), Starting service, revision 3.0.1699.0
10:41:21.843|16e4|.\VoiceMenuCreator.cpp(606): VMCreator, VxmlCreatorSetLog(), External log has been set for VoiceMenuCreator dll
10:41:21.843|16e4|.\VoiceMenuCreator.cpp(64): VMCreator, CVoiceMenuCreator::Init(), Initializing, revision 3.0.1699.0
10:41:22.312|16e4|.\3CXIvrService.cpp(162): IvrService, MainServiceProc::Run(), Writing global parameters to php ...
10:41:22.312|16e4|.\VoiceMenuCreator.cpp(259): VMCreator, CVoiceMenuCreator::DBConnect(), Connecting to database ...
10:41:22.312|16e4|.\DBAccessor.cpp(543): VMCreator, CDBAccessor::Connect(), Database connect string [dbname=phonesystem port=5480 user=phonesystem password=EF11C93F-3E70-4D6E-A2C9-AC87944EC028]
10:41:23.187|16e4|.\DBAccessor.cpp(582): VMCreator, CDBAccessor::Connect(), Database connection success
So it all appears to be working but it just says the IVR is not found.
any help would be appreciated
Many thanks in advanced.
Regards
Jon
Hi Rob,
I am still having the issue of :IVR not found on 127.0.0.1:5483 appearing every few seconds in the server status screen. I am currently using 3CX version 3.0.1928.0. Could you point me in the right direction as to how you got the update file that fixed this problem.
Thanks,
Mark
Actually it's not fixed. I ended up using an extra PC with XP on it. Everything was working great until today when the XP machine died. Now I have a working 3CX phone system just no VM or DR. Getting some IVR error messages.
I'm trying to work with 3CX support on this. I am also installing this on an almost identical server myself. If I get the same issues I hope to have it figured out soon enough.
Either that or version 4 will be the answer :)
circusduck
