License for 15.5.0 does not work with 15.5.15502.6
greychain
Gold Partner
I had to reinstall 3CX so downloaded the latest version for Debian. Now the system is rejecting the license as it's for a different version. Where can I download the 15.5.0 version from?
v15.5 is v15.5 . If your license doesn't work then it sounds like it's expired.
Thanks for that, but no it's not that easy. It's an NFR license and the license was ok before I reinstalled the system. I think the expiry date was something like 2034. I tried installing from the debian 8 iso but am getting the same error.
If it's an NFR license then I'd open a ticket. 3CX upgraded pretty much every license, even expired ones (except really old license or ones that hadn't activated in really long time) to v15.5 Update 6 since they required everyone to be on that version with the activation server change. So again v15.5 is v15.5 . Now if you have an a v15.5 license and you are upgrading from v12 or something like that it won't take the license as you do the step upgrades (but you don't need to anyways as it works fine when you get to v15.5) but if you are doing a fresh v15.5 install and it doesn't work then either your license is expired or there is something messed up with your license that only 3CX can fix. If you a NFR license you should be able to see the license expiration in the portal.
you have 2 NFR keys,
the one starting with V was used in a v16 alpha and therefore cannot be used in lower versions anymore (a limitation to NFRs). Your secondary NFR starting with 3 is still on v15.5. I have changed manually your V key back to v15.5 to ease the re-activation for the time being.
K7oR0x
