License Limit Reached
infinty.tech
SMB User
I had a very strange situation that happend at one of my client about 30 minutes ago,
I have recieved an email from the 3cx that tell me the following;
Your 3CX license limit has been reached. This means that you cannot make any more calls at this time.
Active calls: [2687,2688,2689,2690,2691,2692,2693,2694,2695,2696,2697,2698,2699,2700,2701,2702,2703,2704]
I'm using the 3cx smtp so the email originated from [email protected]
My extension ranges are from 1xx to 5xx, so I immediately begin to think sh!t i'm being hacked, so I disconnect the server from internet and begin to look in the call logs, and event log, but I cannot find anything that will relate of point in the direction that those extension made a call or registration request or that i'm being hacked.
Details of the installation,
276 extension
we are using voip ( so the ports are open)
version: 16.0.641
all the extesions have the Disallow use of extension outside the LAN enable
Those aren't extension ranges. Those are call numbers. Activity log, filter by call and use one of those numbers as a starting point.
Reactions: JohnS_3CX
"Code red" is a service that many cities use, to tell you trash pickup is going to be late. I block the numbers for them that I find and that stops this for the most part.
Look at what @cobaltit said, and you can find out what those calls were.
Once you know who called who you can then act accordingly
Hi Cobaltit,
Thank you for you reply, in the activity log I don't get nothing, and on the call log when i filter for those numbers I don't get anything
This is a very very strange situation
look in the call log for something like this:
What @cobaltit means is in your Management Console go to Dashboard --> Activity Log, and here press the "Filter" button, then you can search there for this CallIDs.
Also because they are sequencial, I do not suspect any "stuck" call in the system, but I would lean towards:
  • The obvious - There were actually this many calls being made
  • You have some kind of logical "loop" that causes this. A case I had seen once is a DID, going to a Queue, no agents logged in, forward to exernal number, and the external number was another DID pointing to the same Queue.
2B_JPS
