Line selection on Line Key in 3CX phone template
SonnyH
Is there a way to set which line a line key can select?
On the Fanvil, I can select which line a line can select, but the 3CX template over-rides the phone BFL settings.
Hi @SonnyH,
Do you mean that when the phone reprovisions that the BLFs you've configured disappear?
Did you set up the BLFs on the phone itself or via the Web Client / Windows Client? Because 3CX reprovisions the phones on a regular interval, the BLFs should be added via the Web Client / Management Console and then they'll stick around once the phone reprovisions itself.
I don't think there is a way to choose which trunk to use using keys on the phone. The only way is to configure the outbound rules. For example you could use a prefix (9 or other digit) to go out with a particular trunk.
The BLF keys must only be configured from the 3CX console in Extensions -> Phone Provisioning.
K7oR0x
