Linksys SPA-3102_unable to configure
MikeMelga
Hi.
I am using 3CX for some time now. I have a analog gateway (SPA-3102), a GSM gateway (Portech MV372) and 2 voip lines. Everything is working ok but one of the things I still haven't been able to do is properly configure the SPA-3102.
Currently I am able to both receive and make calls in 3CX using the SPA-3102 with no problem.
My problem is that I have an analog phone connected to the SPA-3102 that I never got it to work.
Can I have that analog phone configured as an extension? What I would like to do is be able to dial and receive calls on that phone.
How can I do that?
I had some help some time ago here:
http://www.3cx.com/forums/integrating-ata-gateway-and-2-ata-phones-33055.html
but never got it work :(
Can someone help?
Thanks.
Leejor, I plugged in the ethernet cable into the blue internet port and powered cycled the 3102. Still no joy. I am going to try a Cisco SPA 112 to see if that works. Not sure why the 3102 won't work as a remote extension. I know alot of people have gotten them to work.
Ok, I figured out the problem. It actually wasn't a problem with the 3102 or the SPA 112. The issue was with my Cisco ASA 5505 firewall. I did not have SIP packet inspection enabled. Once I enabled packet inspection the Cisco SPA 112 registered right away. Hope this helps someone.
ARKC
