so i can not put it right?
Good morning and thank you very much for the answer.@Nikos To
You will have to access the Wordpress admin panel, on the left click on "Live Chat >> Settings", click on "Advanced Features", select 3CX and then a field will appear to add the "3CX Click2Talk" URL which you can get from the 3CX Management Console:
Have you not updated as per VasilisV_3CX? Which version of Wordpress and which version of the 3CX Live Chat plugin are you running?It seems in the version I have there is no such option.
I put a version 8.2 maybe I will save the upgrade but Mitsotakis did it for me ..Have you not updated as per VasilisV_3CX? Which version of Wordpress and which version of the 3CX Live Chat plugin are you running?
Wordpress: Check under Dashboard >> Updates
3CX Live Chat plugin: Check under Plugins >> Installed
Do you mean Wordpress 4.8.2? If yes, you will have to upgrade to Wordpress 5.3 or higher as mentioned previously and as mentioned here.I put a version 8.2 maybe I will save the upgrade but Mitsotakis did it for me ..
in the version of the plugin I was referring toDo you mean Wordpress 4.8.2? If yes, you will have to upgrade to Wordpress 5.3 or higher as mentioned previously and as mentioned here.
In that case, do note that the current version of the 3CX Live Chat plugin is 9.3.1 so you will have to upgrade to that. Before upgrading it though, do make sure that your Wordpress version is at least at 5.3 or higher. Check Wordpress version in Dashboard >> Updates.in the version of the plugin I was referring to
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
