Solved Login access denied without blacklisted IP
apitsos
SOHO User
Hi there,
I am trying to login on my own 3CX system from a specific IP and I am getting the following error message:
Login access denied. Too many incorrect login attempts. Try later or contact the Administrator.
After checking under under IP Blacklist, I confirm that this particular IP from which I cannot login, is "Allowed"...!
No mater how much I wait to retry, I am always getting the same error. Even if I try a week later. But from any other IP I am trying to login with the same credentials, I am logged in without any problem.
Any ideas why is that happening, please?
With kind regards,
Angelos Pitsos
You also need to specify the IP under Admin Console Restrictions too.
Hi @kieferschild!
Thank you so much! That did the trick... ;)
I completely forgot this section for the security settings.
Wishing you a great weekend.
With kind regards,
Angelos Pitsos
I'll be marking this a solved as everything seems to be in order.
Reactions: apitsos
apbGroup
