Login not Possible in Cloud 3CX 1Year Free
dominikheidegger
i hope you can help me.
The Free Version of my 3cx does not let me in.
It says:
Login access denied. Too many incorrect login attempts. Try later or contact the Administrator.
I have tried it with every last Login and there is no way to change the login or something.
i hope someone can help me.
best regards
Hello @dominikheidegger
The error you are getting suggests that your IP has been blacklisted after too many incorrect login attempts. You will need to try to login from a different IP and remove your IP from the blacklist. The PBX can also send the login credentials to the email set as the administrator of the PBX after 2 failed login attempts.
Got it thank you
Glad i could help. Let us know if further assistance is required
megalmazan
