Solved Logo Placement on v65 (Hosted Pro License)
mf202
New User
Is there anything I can do to move (or remove) the logo on the Pro Hosted (other than upgrade to Enterprise so I can load an all back logo)?
Hi there.
Unless you create a custom template and this is not something we support.
P.S. Custom templates are not available in 3CX hosted.
So, if I want to use the 3CX hosted solution, is the only option to upgrade to enterprise so we can load a "black" logo? Thanks!
When is the new 3CX being deployed for hosted? Seems this will resolve the issue.
“3CX's wallpaper will be updated in the next version”
It seems that your phone is running on the older firmware, can you please ensure that your firmware is up to date and it's the same as mentioned here
Reactions: mf202
Did the phone firmware update resolve your issue?
Perfect, and thank you for the feedback.
Hassan Murasan
