Looking for provisioning template for Panasonic KX-HDV330
Chris9000
Hello all,
We are setting up our own PBX as we speak, and have existing KX-HDV330 devices. I found an old thread: https://www.3cx.com/community/threads/panasonic-kx-hdv.52531/
Where somebody said you can use the template from the KX-UT series when it was supported in 3CX version 10/11. Sadly that attachment file is not downloadable anymore.
Could somebody help me out with this please?
Try contacting Panasonic Support. Usually the mfg makes the template for 3cx support.
You could always export a working config from the phone and roll your own.
This is the file that was attached to that thread you reference.
You will have to update the models and add additional IF rules - ie:
{IF Model=Panasonic_KX-UT136}
Reactions: Chris9000
Wecare_ITA
