M365 User Sync - Schedule / Force
lancerichards
Platinum Partner
Hi All,
I have a system where we have enabled M365 for user sync / SSO.
The issue we are facing is that the refresh of the user does not seem to be happening and we are not seeing user updates.
I have disabled "Sync Microsoft 365 Users", done a service restart, then re-enabled - still no user sync updates.
I've left it for a few days as the documentation says "The synchronization is one-way (MS365 to 3CX) and happens once per day, during the night." but I've not seen it sync for a few days. (https://www.3cx.com/docs/manual/microsoft-365/)
The M365 integration shows to be all ok...
Code:
Your Application ID for reference is db83e0f2-3c78-495b-a0e2-xxxxxxxxxxxxxxxxxx
Status OK. Real Time Notifications from 3CX to Microsoft 365 are working and in sync.
Nothing shows in Verbose logging either for M365 user sync.
Is there a command line option to force a sync and get some logs?
Best,
Lance
Have you tried doing a reconfigure of the M365 integration? That should clear out any bad state on either side and regenerate tokens etc properly. If the integration was fine it should result to 0 changes on the PBX or Azure side, so fairly safe to try - but as always do take a backup before.
I would also check the time on the server for any time drift, just in case.
Have you got any restrictions in 365 such as conditional access or such?
Thanks @KyriacosS_3CX
We'll start with that and see how it goes.
@Alphabetic we don't manage the IT environment, so I'm not sure what they have configured but thanks for the thought :)
Best
Lance
Very interesting one, it ended up being that the IT provider didn't have a First Name or Last Name on the user, only a Display Name.
3CX therefore couldn't bring the data in to match.
Some other interesting things which were helpful here were the OFFICE365_ parameters which allow you to kill off the connection and change the sync time.
Best
Lance
/dev/simon
