- Joined
- Mar 13, 2019
- Messages
- 2
- Reaction score
- 0
Hi, im new to the forum, hope im posting in the right place.
I have been tasked with writing a script to make an outbound call using 3CX.
Our database software has the ability to trigger a call using Skype or Windows Dialler automatically, but these are launched from a separate VB Script. I was thinking i could modify the script so that instead of launching skype and appending the number to the command, i could change it to 3cx append the number and launch.
Unfortunatley, i cant seem to get the script to work with 3CX. So two questions:
Many thanks for the help in advance.
- Can you tell 3CX to dial a number from the command line and if so, what is the syntax?
- If that can't be done, can you force dial.exe (Windows Dialler) to route via 3CX instead?
