Manage console restriction IP addresses via API
kosli
SMB User
I couldn't find anything in the API documentation if it is possible to configure the console restriction IP addresses via the API?
-> The question is for a 8SC PRO licensed PBX.
Thanks.
XAPI, check the Swagger. Or F12/DevTools when you open the console restrictions and simply reverse engineer it.
Thanks @ConceptsWeb
found the /xapi/v1/ConsoleRestrictions but realized that the XAPI is only available for enterprise licenses. what a pitty. will have to find a "manual" way to via the web ui :-(
Thanks @ConceptsWeb
Use the Webclient login endpoint to get a token. It will work.
Netflo
