Solved Management Console
john wright
Hi all,
Ive just moved some of our hosted installs from the old cloud provider to lightsail
The problem i have the URL has changed it used to have a port https://fqndname.3cx.co.uk:5001/#/login and now on lightsail its missing the port https://fqndname.3cx.co.uk/#/login
Everything works but when customers try to use the click to call or the web interface we have to login to each PC and change and delete the port number in the stored URL.
Is there a way i can add the port on the new install using PBX express
thanks
No. PBXExpress uses 443. If you want to use 5001 you'll have to do a manual install (which is not that difficult and is what I do anyways.
Sorted now thanks, i just did as you said and done them manually at least that way all there old links still work
thanks
Glad to see the issue has been resolved
Rich Hopkins
