Manually provisioning SPA525G
Nazrul
Hi All,
Kindly advise parameters for Manually provisioning of IP Phone SPA525G with 3CX .
Naz
Hi Nazrul,
I have got you from your previous forum conversation : https://www.3cx.com/community/threads/zoiper-sip-softphone.82831/
Please try the following steps to configure the 3CX extension manually.
1. Enter the Extension User Name or EXT number as Display Name.
2. Enter the Extension number
3 & 4. Get the details as I mention in the following image.
5. Enter FQDN:SIP PORT (Example: test.my3cx.sg:5060)
6. You have to change "YES" in Use Auth ID:
Thanks,
RA.
Thanks RA,
i will give a try and Update you the Outcome.
is that any reason , i am unable to ping FQDN ?
Naz
Hi Naz,
Where did you host your PBX?
Hi RA,
I have hosted in AWS Cloud.
Hi Nazrul,
That is a different matter, but if you google "cannot ping AWS instance" you will learn more information.
Firewalls do not allow all traffic by default, you might need to add a rule for it.
Hi JohnS,
is Firewall rules require to add inside 3CX Server ?
Naz
No, this has to do with the AWS instance - not the 3CX Server running inside of the instance.
I would recommend to research it online and learn more on how it works.
Reactions: Cal4care | RA
Thanks JohnS , Sure i will find out.
Stephan Eusebe
