Migrate 3CX from Windows platform to Linux(Debian) platform
darshana
Intermediate Cert.
Hi there
Our office has a 3CX installed on Windows, and I want to migrate it to Debian, without losing any configs and data, anyone could you please help me with the process step by step.
Hi Sorry for the late reply, we are still using ver 16, can I assign a new IP to the new server?
Thanks, we've used the fqdn to provision the phones, so guess we have to point the new IP to that fqdn, then its fine i assumn
HI Decided to use the same IP and FQDN, so guess this is easy?
backup V16 version in Windows with IP and License, recording,
then shutdown the Windows server,
Install new 3CX V18 Dabian with iso then import from backup in wizard?
Yes, that would be what you want to do:
  1. Shutdown Windows
  2. Install 3CX from ISO and finish the installation and restore the 3CX backup
  3. Log into the via SSH and change the IP Address of your Debian to match what your Windows machine had
    (Guide here, see section "Configuring Static IP on Debian 10 or 11")
  4. Log into the Management Console --> Dashboard, click where it says "IP mismatch" that will have appeared probably, set the new IP from the drop-down
  5. You are set to go!
Zexus
