Missing some system settings
Vario777
Hi all,
recently noticed that the instance is missing some tabs in Settings menu
there are no License, Network, Parameters and System Prompts tabs.
The license itself is activated.
any ideas?
Reactions: Vario777
thanks!
Is there any way to enable it?
If you have used the 3CX one year free hosting then you will need to move the PBX to an instance you control.
If you installed the system on your own instance using the hosting admin feature then you will need to re-install the system or access the system via the hosting admin account.
Reactions: Vario777
ok, noted.
thanks
Glad i could help
megalmazan
