More info on the v16 digital receptionist's "Launch Script" option?
dandenson
SOHO User
What can we do with 'Launch Script'? Is this a linux script ie bash/python/etc or is this for call flow stuff?
Reactions: rsh
Any news about this function?
Some basic information on what a digital receptionist can do can be found here:
https://www.3cx.com/docs/manual/ivr-digital-receptionist/
The launch script function can take a users input and pass them on to a script you write. This can be any script that can executed by the OS the PBX is running on. For windows for example it could be a .bat file. The same file however would not run on Linux. You could then (optionally) have your script return a value to the PBX and set that value to perform an action.
That's a very good feature! So I can, theoretical, windows-services stop/start with a single 3xc-call, wih a .BAT or .PS file ?
Yes, something like this could work:
10206
This example will Start/Stop the 3CX Tunnel service, so probably a bad idea, but it can be done.
avmullins
