multi-tenant extension ranges
rbergthold
i am not seeing extension ranges as an option if i go to add another department. It seems i should be seeing that, per step two on: https://www.3cx.com/docs/multi-tenant-configuration/. If i missed something, can you point me in the right direction? if I have to blow it out and start over, no big deal.
Well that indicates that the system is installed as dedicated and not as Multi Tenant.
If you go to the system Menu --- Multi Tenant, do you see it is enabled?
i was worried this might happen. I am reusing a license that I upgraded to 16Pro SC. I followed the steps in this setup guide, and saw nothing to check for Multi-Tenant. i obviously missed a step. i will blow it out and reinstall
i guess this is a question i never heard asked. Am i still able to install on AWS Lightsail?? i see my license key under Your 3CX Systems. However, if i go to Downloads > 3CX Multi-Tenant > Install, the key doesn't show up there. It is a 16sc Pro.
that's awesome! i just upgraded our 32SC Enterprise edition. Where do i go to switch to Multi tenant mode?
guessing it's this bad-boy:)
Hi from where did you found this setting? on which release this is available?
update 6 Alpha on the dashboard:
@NicholasP_3CX , thank you so much for all of your direction. Say, "Hi," to Stick!!!
Reactions: NicholasP_3CX
jbergeon
