Multicast On hosted 3cx
sfraz
I am unable to find the option to enable multicast under users >> phone provisioning. however I do have a ring group setup for multicast. I am wondering our pbx is hosted and not same network does that matter? phones are set with SBC. open to suggestions. currently using paging and it takes 5 seconds minimum for all phones to connect looking for something instant.
You cant use multicast on a hosted instance, its something for on a local network
Thanks for the reply what you recommend I do client is asking for something like multicast. Paging is too slow to connect.
Move on-prem.
Reactions: sfraz
would it work if I hosted the pbx on self-hosted cloud and vpn site to site ?
Good point! If you have a site-to-site VPN, the PBX would, for all intents and purposes, be local to the phones and multicast should work.
Have you managed to solve this problem? If yes, then what did you use? I want to translate my some medical documents and that's why i am looking for it online and while i am looking for it i found this website https://pickwriters.com/healthcare-translation-services here i can see many sites in this website in this i can read the reviews of these sites which helps me to find the best website for me.
We offered the client to move the server on-perm they said They can wait 5 seconds to connect.
DejanMDS
