- Joined
- Jan 11, 2021
- Messages
- 8
- Reaction score
- 0
There are two IP devices on a subnet. They're of the Mitel type, but it doesn't matter. The basic problem is that both extensions log on to the 3CX subcenter on port 5060. They can't call each other. Mobile extensions works, but I can't bring more than one IP device to life. With port forwarding, I can only direct port 5060 towards one device. What is the way that all IP devices can connect to the 5060 port and make calls work properly? Maybe the 3CX admin panel can help you with that?
