Solved Multiple 'out of hours' rules for same day
RobC
Forum User
Can anyone suggest a way to achieve the following for a Ring Group with a single DDI/Inbound rule?
9:00am - 4:00pm: ring normally
4:00pm - 6:00pm: forward to an external number
6:00pm - 9:00am: forward to voicemail
You can create a DID Inbound rule, and set custom opening hours 9:00am - 4:00pm
Then for the rest of the hours, you can set the " Destination for calls outside office hours" to a dummy extension, and enable Autoswitch in its forwarding settings.
The dummy extension can have custom office hours 4:00pm - 6:00pm and sending the call to the external number under the Available status.
And then for the DND status, send them to a voicemail (covers the 6:00pm - 9:00am window)
Great idea - thank you very much. I wasn't aware of the Autoswitch functionality. Is that quite new?
Nope, been around for a while actually :)
Give it a go and let us know how it works out
Works really well. Thank you so much for showing me the way!! :)
Hi All,
I would suggest using CFD if it ends up getting more complicated than this, as I believe editing a single CFD file to make changes to your hours is better, in the long run, than editing multiple DID > extension point rules.
EMMEPICASA
