Multiple SIP Trunks/Accounts with same Provider
ajohnson443
New User
I use Callcentric and have one SIP trunk up and running fine for a long time. Added a new sip trunk from callcentric from a separate account and when I try to route outbound calls over the 2nd trunk it gives me an authentication error in the log. I read in another post that some providers can't support multiple sip trunks from same IP. Could this be the same issue?
03/19/2020 12:12:07 PM - L:85.1[Extn:200] failed to reach Line:10001>>19041234567, reason Forbidden
03/19/2020 12:12:07 PM - Call to T:Line:10001>>19041234567@[Dev:sip:[email protected]] from L:85.1[Extn:200] failed, cause: Cause: 403 Incorrect Authentication/INVITE from 204.11.192.159:5060
03/19/2020 12:12:07 PM - [CM503003]: Call(C:85): Call to <sip:[email protected]:0> has failed; Cause: 403 Incorrect Authentication/INVITE from 204.11.192.159:5060
03/19/2020 12:12:07 PM - [CM503025]: Call(C:85): Calling T:Line:10001>>19041234567@[Dev:sip:[email protected]] for L:85.1[Extn:200]
03/19/2020 12:12:07 PM - [CM503027]: Call(C:85): From: Extn:200 ("Spears" <sip:[email protected].3cx.us:0>) to T:Line:10001>>19041234567@[Dev:sip:[email protected]]
03/19/2020 12:12:07 PM - [CM503004]: Call(C:85): Route 1: from L:85.1[Extn:200] to T:Line:10001>>19041234567@[Dev:sip:[email protected]]
03/19/2020 12:12:07 PM - Line limit check: Current # of calls for line Lc:10001(@CallCentric_Spears[<sip:[email protected]:0/UDP>]) is 0; limit is 3
03/19/2020 12:12:07 PM - Call(C:85): Call from Extn:200 to 1234567 matches outbound rule 'Spears_Local'
03/19/2020 12:12:07 PM - [Flow] Call(C:85): has built target endpoint: Out#:>>Rule{Spears_Local}>>9879575 for call from L:85.1[Extn:200]
03/19/2020 12:12:07 PM - [Flow] Target endpoint for 1234567 is Out#:>>Rule{Spears_Local}>>1234567
03/19/2020 12:12:07 PM - [CM503010]: Call(C:85): Making route(s) from Extn:200 to <sip:[email protected]:0/UDP>
Ultimately it depends on whether you are registration based or IP based. Which trunk type is it and have you talked to Callcentric?
Reactions: ajohnson443
Multiple sip with same providers do work 100% i have 4 using account based, no need to mess around with sip ports either
Thanks. Did you have to do anything at all differently in the trunk config? I am account based also and using two accounts. One is my personal account (works fine) and the other is a partner who needs me to let him use my PBX to route his calls for a while. Both are Callcentric accounts.
Hi @ajohnson443 no nothing at all, no special configs or anything, just simply added them using port 5060 for all of them.
Make sure you have the latest update on your PBX - V16 Update 4
Make sure both trunks are correctly configured (DID and credentials)
Modify your main outbound rule route to use the 2nd trunks and retest
Could it be SIP provider security mecanism protecting against another Public IP registration?
Callcentric has this as a security measure, but the trunk would not register at all if this was enabled on their portal
Thanks for the input. I finally heard back from callcentric and after looking at some screenshots they had me make the following changes.. It worked. Still not sure why one trunk works without this and one needs it but hey.. I'll take it :)
Mar 19, 2020 09:06 PM : Customer service
Please change the setting below under the Outbound Parameters page:
Reactions: luckys
Perfect, glad its sorted
Hi @ajohnson443
Create a new trunk using our Callcentric template, notice the default parameter we have for the
If yours was not like this then you were not using our template, or perhaps you clicked the CenturyLink template by mistake when you were creating the trunk (its just below the Callcentric one and has a different value).
If you want to be 100% certain, make sure your templates are updated and re create the trunk from scratch just in case there are other parameters that are also different and may cause you future issues when the time comes
Funny thing is that I did use the template for all of them. I will follow-up on this and make sure they are set right. Thanks!
Hi @ajohnson443
Update: My original trunks are exactly the way they should be.. I have no idea how that setting was different on the new trunk.. I "know" I used the template..... :oops::rolleyes:
Schnittker
