My installation is on-premise but is marked as self-hosted
colinjh
My installation is on-premise but is marked as self-hosted.
How would I change this so I can ask a question under on-premise part of the forum?
When your key was deployed?
Yes, originally it was self-hosted, but it now has been moved to on-premise about 6 months ago.
What is the installed version?
Are you able to activate?
It has been running for the last 6 months as on-premise.
Running 18.0 Update 9 (Build 20)
When I try and start a message in the on-premise part of the forum I cannot select the system as it's not there, but when I come here it is, as I started this thread under that system id.
This is not the last update... Are you able to activate/refresh your licence on your 3cx?
Reactions: TheodorosG_3CX
Yes, the licence is activated and can be refreshed.
The system has been working for the past 6 months. It was installed on premise with no problems at all and has been working well.
I just want to post a thread in the on-premise section of this forum as I have a problem on the system, unrelated to the licence.
To post a new thread I'm required to enter the system id, which the forum doesn't list the system id under the on-premise section, as I wish to place the thread into the correct section.
The short version is, this is the way it is. I’ve asked a few times. Just post where you can.
sambannoura
