My Phone number showing as a spam for receivers, and it is listed in few sites, Can you pleas suggest us how to request them and whitelist my number.
ssv
This is something you need to discuss with those sites maintaining the spam lists and possibly your provider.
There might also be a valid reason this has happened in the first place, so you will have to look further into it.
If it is samsung they have a provider called HIYA
https://www.hiya.com/products-smart-call
I had a customer where their number was showing as a flower shop (which they wernt) sent a support request and they sorted it quickly.
Hope that helps
I would be very concerned at to why your number has been added to a blacklist. Some Scam callers have a nasty habit of using legitimate, active phone numbers, as their caller ID. Perhaps this has happened here. If this is the case, then even if you have it removed, it may quickly be back on one list, or another.
Reactions: JohnS_3CX
Reactions: NickD_3CX
florentrobineau
