- Joined
- Mar 12, 2020
- Messages
- 17
- Reaction score
- 2
Just new to 3CX and evaluating the purchase.
During an attempt to get a Dialogic Brooktrout SR140 to work as a fax extension with 3CX, I managed to get the SR140 to register it as the default 888 fax extension.
Anyway routing inbound faxes to the fax wasn't working (line dropped immediately).
After removing the registration settings on the SR140, to my surprise, I can't get the native fax to email working anymore.
It just hangs the line with a 480 no matter what extension I pick (in this case 543).
| 03/16/2020 10:27:00 PM - Leg L:7.1[Line:10000<<redacted530] is terminated: Cause: BYE from local |
| 03/16/2020 10:27:00 PM - [CM503008]: Call(C:7): Call is terminated |
| 03/16/2020 10:27:00 PM - Leg L:7.2[Fax:888] is terminated: Cause: BYE from local |
| 03/16/2020 10:26:58 PM - [CM503007]: Call(C:7): Fax:888 has joined, contact <sip:[email protected]:5483/UDP> |
| 03/16/2020 10:26:58 PM - [CM503007]: Call(C:7): Line:10000<<redacted530 has joined, contact <sip:[email protected]:0/UDP> |
| 03/16/2020 10:26:58 PM - L:7.2[Fax:888] has joined to L:7.1[Line:10000<<redacted530] |
| 03/16/2020 10:26:58 PM - [CM503002]: Call(C:7): Alerting Fax:888 by contact <sip:[email protected]:5483/UDP> |
| 03/16/2020 10:26:58 PM - [CM503025]: Call(C:7): Calling T:Fax:888@[Dev:sip:[email protected]:5483;rinstance=fbc094450ded1422] for L:7.1[Line:10000<<redacted530] |
| 03/16/2020 10:26:58 PM - [CM503027]: Call(C:7): From: Line:10000<<redacted530 ("redacted530" <sip:[email protected]:5060>) to T:Fax:888@[Dev:sip:[email protected]:5483;rinstance=fbc094450ded1422] |
| 03/16/2020 10:26:58 PM - [CM503004]: Call(C:7): Route 1: from L:7.1[Line:10000<<redacted530] to T:Fax:888@[Dev:sip:[email protected]:5483;rinstance=fbc094450ded1422] |
| 03/16/2020 10:26:58 PM - [Flow] Call(C:7): has built target endpoint: Fax:888 for call from L:7.1[Line:10000<<redacted530] |
| 03/16/2020 10:26:58 PM - [CM503010]: Call(C:7): Making route(s) from Line:10000<<redacted530 to <sip:[email protected]:5060/UDP> |
| 03/16/2020 10:26:58 PM - [CM505003]: Provider:[Alcatel OXE] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:[email protected]:5060] Before it was working fine and I have no clue regarding what to do. It seems to me that 3CX FAX is broken/not working somehow. I already rebooted premanently dc the SR140 etc.. Is there any way to reset fax settings to default or undo the actual situation without reinstalling? |
