Solved Net2Phone SIP trunk- No outbound calls
Cascada
I have several installations using Net2phone on the "old" platform without any issues. However, they "update" their platform and any new order is assigned to the new platform.
I just received the credentials for a new customer. I configured the SIP trunk and this is the situation:
  • The trunk shows green.
  • I am able to received phone calls (the old platform used 10 digits for the main number, the new one requires the "1' in front of it -- my location is USA)
  • Outbound calls are failing. The log shows the following error:
05/08/2019 1:54:45 AM - Call to T:Line:10000>>4079000638@[Dev:sip:[email protected]2phone.com:5060] from L:19.1[Extn:102] failed, cause: Cause: 410 Gone/INVITE from XXX.XXX.XXX.XX:5060
For security reasons, for this post I masked the user name with "1111111111" and the from address with XXX.XXX.XXX.XX
Is anyone having a similar issue with net2phone?
Hi Cascada
Do you use E.164 processing on this PBX by any chance?
If you send the call out with the "1" prepended in front will the call succeed without getting a 410 Gone?
The invite should then show T:Line:10000>>14079000638 if this is the format they want under the new platform
Thank you JohnS. Problem solve!
Glad it was resolved!
devo.it
