New Customer / Partner Portal
Natassia Allery
Head of Customer Support
Platinum Partner
Shopping cart allows multiple key ordering & renewal. Bigger hosting packages too.​
We’ve completely refactored the Shopping cart giving you the long awaited ability to order, renew or upgrade multiple licence keys at once before proceeding to checkout. Overall, it’s much faster too! Read on to find out more.
Easi...​
Hi Natassia,
Thank you for the update.
The shopping cart is brilliant as it makes it much easier to purchase multiple licenses.
Is the option for wire transfer payment no longer available?
Hi Peter
The option is still available on the last step. You can select the payment method from the drop down above.
Also if you use PO in your company, you can click on the Option Billing Information to add the PO.
Thanks Andreas,
I see the option for Wire Transfer now.
When I tried it earlier I was only getting the below options:
Reactions: AndreasA_3cx
justcallmeshiv
