No audio on call pickup
eddv123
Titanium Partner
3CX is v16 SP3 using Yealink T46S phones firmware 66.84.0.95 (latest 3CX supported).
Anyone experienced issues with the above, as I cannot get to the bottom of this particular problem so looking for some advise
on something I have noticed when tracing.
3CX system is hosted, with VPN tunnel down to the customer premise. Handsets involved in the issue are all on the same site.
Customer uses the call pickup feature https://www.3cx.com/docs/pbx-dial-codes/#h.m824f8l4wxkq and gets no audio traffic on the picked up call.
When looking at a PCAP of the problem (fragment from the effected endpoint attached) I see all the normal elements of a call pickup in the trace
(using ** as our pickup code) and actually see RTP being sent both ways (192.168.254.1 being the PBX, and 10.20.14.51 being the endpoint initiating the call pickup)
but wanted to query this ICMP destination/port unreachable packet (which I have seen before in other traces but not taken notice since it has not ever been related to an issue).
The RTP in this case is using random ports 7004 on the PBX side and 12230 on the handset, these are both noted in the ICMP packet as source and
destination ports. Seems a bit of a coincidence based on the issue, however unsure so experience and feedback welcome.
Sure it to be a network level problem but what leads me to doubt is that if this were, it would not make sense since the endpoints and system are all connected by rout-able subnets/LAN to LAN IPSec VPN with traffic at layer 3 through the VPN interfaces from these subnets allowed.
Note: Have tried with both "PBX Delivers audio" on and off also.
Reactions: JMazio
Do you have the same behavior if you pickup the call from the webclient instead of the Yealink?
Hi @eddv123
I can at least confirm for you that in a local environment running v16 SP3 using Yealink T46S with firmware 66.84.0.95 the call pickup works like a charm. However, my phones here are all on the same IP range.
Have you tried reprovisioning the phone yet or maybe run a capture from the Yealink UI ?
@JohnS_3CX I agree, I have no other sites reporting this issue (and we have a lot) which is why I am convinced it is a networking problem, however wanted confirmation on the error I am seeing.
Not tried a reprovision, but can. The capture is from the Yealink PCAP feature. I have one from the phone and PBX interface/3CX.
If there is wireshark playable audio in the Yealink's PCAP but it is not being played on the endpoint I would just factory reset and reprovision.
Under these conditions there is no reason to think that the device can't reproduce it, but there is reason to think that it refuses to play it I would suspect.
Wecare_ITA
