no incoming calls since v16 update
Senzo
my 3cx system won't receive calls but can dial out. This started after v16 alpha update two days ago.
i have tried to re deploy the pbx on a different google instant and getting the following error:
There was an error while creating your 3CX Cloud PBX. The error message is reported below:
Error in XML file. RequestCode = 'LicenseKey': Invalid License Key."
help please
Hi Senzo,
Did you try to deploy using PBX Express and if so, did you try to restore from a backup file during the procedure?
i am using pbx express and the install fails. getting msg "Error: Error in XML file. RequestCode = 'LicenseKey': Invalid License Key"
Oops, something went wrong....
Looks like you did not setup your Google Account with Google Cloud features.
Look at this guide to make sure you have completed the required steps.
We have sent you a PM
jmarshall
