no NTP sync with v20?
David_K
Hello
This morning we were not able to connect to one of our v20 serversn not even with admin account.
We were rejected with a "login/password incorrect" error, but we had this error after entering the MFA code, so to me it was not a password issue but something to do with MFA
After SSH login, noticed our server time was almost 10 minutes behind. So updated the time and MFA went OK
Question : is there no NTP client installed by default with the v20 .iso ?
Is this a 3CX Hosted installation or self-hosted?
Is it on a HyperV?
No Hyper-V but KVM I believe since it's installed as a VM on a public cloud
You will need to check if the NTP sync is correct in the VM in this case.
Let me know the outcome
erre
