No option for protocol configurations changes for Pro license with 512 concurrent calls
Ferdnand.ouma
why don't I have the option to change transport protocol for the default UDP to ANY under configurations on one of my 3CX instance with 512 concurrent calls professional license, yet I can do this for the same professional license with 256 concurrent calls with the same update version
It's not related to your license. It actually depends on the capabilities of the provider you selected.
When using a supported provider you can only use the supported options of their profile.
If you add a generic trunk, you can see the settings exposed:
C1744291345910.png1744291417729.pngCompare the two, both Pro license but one doesn't give you option to change the protocal type.
Both instances were deployed with Worldwide-Asterisk as provider
Please navigate to the Voice & Chat section and click the 3 dots next to both trunks then click Export on both trunks. You should get 2 .xml files, 1 for each trunk.
Look in the header section of the exported files for the template name. Is the template used the same? It should be something like asterisk.pv.xml.
@Ferdnand.ouma
If you need it quickly without reimport the trunk and assign DID:
lastshadow
