No voice on Dialing internal Extensions
clemy246
Hi Guys , Please assist when i dial internal Extensions there is no voice , but when i transfer incoming calls to extensions is working , the yealink phones are connected via Provisioning Method Direct SIP (STUN - remote)
Thank you for your assistance.
Hi @clemy246,
To clarify, if:
  1. Ext A calls Ext B, there is no audio. If Ext B transfers Ext A to Ext C, is there audio?
  2. External call to Ext B, there is audio? Or Ext B transfers to Ext C and there is audio?
Feel free to use the example above to describe your issue in more detail.
Hi @clemy246,
To clarify, if:
Thank for your reply Vasilis, internal calls , Ext A calls Ext B, there is no audio. If Ext B calls Ext A no audio
incoming call from outside number to Ext A is there audio Yes
Ext A transfer to Ext B is there audio Yes
Ext B calls Ext C or Ext A is there audio NO.
@clemy246,
I assume that if Ext A calls Ext B, and Ext B transfers that call to Ext C, there is no audio?
Hi @clemy246,
Have you enabled PBX delivers audio on all of the extensions involved?
To check open the Extension in the Management Console >> Extension >> Options >> Troubleshooting >> Check the PBX delivers audio box.
Yes i am anble PBX deliverys audio box to all extensions but still no voice
Hi @clemy246,
Have you had a look at our STUN phone troubleshooting guide? I highly suggest taking a look at it and ensuring each criteria is met, such as the server configuration steps.
What type of router are they behind, and how many extensions at the location?
Was this working at one time?
Hi leejor,
There are 4 Extensions at the location
Huawei LTE B535 Router 3 Pro
It has never worked on internal extension, I can only dial external numbers on all Extensions and working perfect good quality audio.
BIT Incorporated
