Solved No Voicemails
Steve123
  • 3CX Version: Standard Annual 18.0.237
  • Server OS, Debian 9
  • Is the 3CX Server Hosted and where? On-premises
  • IP Phone Make/Model/Firmware version, SPA504G and 3CX Softphone
  • Provisioning Method: Local
  • Trunk Provider or VoIP Gateway Make/Model, SPA 3102
  • Has the Firewall Checker passed: N/A
Hello all,
I've managed to get the PBX installed, and inbound and outbound calls working. When someone leaves a voicemail, the red light on the SPA504 lights up, but there does not seem to be any way to retrieve it. I have tried:
  • message button on the SPG504G
  • Dialing 999 on the SPG504G
  • Dialing 999 on the softphone
  • Looking at the voicemail page of the softphone
but no where do there seem to be any voice mail messages. Below is an extract from the activity log where:
10.65.0.201 is the SPA504G
10.65.0.202 is the 3CX PBX
10.65.0.203 is the SPA3102
11/09/2021 5:05:07 PM - [Flow] Target endpoint for 999# can not be built!
11/09/2021 5:04:51 PM - [Flow] Target endpoint for 999 can not be built!
11/09/2021 4:52:01 PM - [CM503003]: Call(C:35): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 10.65.0.201:5060
11/09/2021 4:43:48 PM - [Flow] Target endpoint for 999 can not be built!
11/09/2021 4:40:24 PM - Call to T:Extn:100@[Dev:sip:[email protected]:5060] from L:29.1[Line:10000<<10000] failed, cause: Cause: 486 Busy Here/INVITE from 10.65.0.201:5060
11/09/2021 4:40:24 PM - [CM503003]: Call(C:29): Call to <sip:[email protected]:0> has failed; Cause: 486 Busy Here/INVITE from 10.65.0.201:5060
11/09/2021 4:40:23 PM - [CM503003]: Call(C:28): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 10.65.0.201:5060
11/09/2021 4:40:03 PM - Call to T:Extn:100@[Dev:sip:[email protected]:5060] from L:27.1[Line:10000<<10000] failed, cause: Cause: 486 Busy Here/INVITE from 10.65.0.201:5060
11/09/2021 4:40:03 PM - [CM503003]: Call(C:27): Call to <sip:[email protected]:0> has failed; Cause: 486 Busy Here/INVITE from 10.65.0.201:5060
11/09/2021 4:37:28 PM - [CM503003]: Call(C:26): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 10.65.0.201:5060
Any ideas on where to look?
Hi @Steve123,
If we're saying that voicemails are not saving at all (checking the Web Client voicemails section as you mentioned, and it being blank), I would check the following things:
  1. If you navigate to Settings >> Voicemail, are you sure you're dialling the correct voicemail number?
  2. Does the disk have space?
  3. Does the recording exist in /var/lib/3cxpbx/Instance1/Data/Ivr/Voicemail/Extensions/[EXT NUMBER]?
  4. If the disk has space, create two new extensions and call internally from A to B, let it go to VM and see if it appears in the Web Client >> Voicemail.
Opps. It turns out the key for VM is 666. I don't know why I had 999 on my mind.
Thank you, problem solved.
Great to hear @Steve123! Feel free to open a new thread if you require any further information or assistance.
apbGroup
