SkyArmy Bronze Partner Joined Jul 20, 2024 Messages 5 Reaction score 0 Jul 20, 2024 #1 Hello All, I have 4SC license and this is the error" Device 10002@(Ln.10002@GSM-02) has reached max amount of calls" Last edited: Jul 20, 2024
SteveITS 3CX MVP Silver Partner Advanced Certified Joined Jun 20, 2018 Messages 4,474 Reaction score 2,189 Jul 20, 2024 #2 That looks like the trunk is rejecting it. What is 10002?
SkyArmy Bronze Partner Joined Jul 20, 2024 Messages 5 Reaction score 0 Jul 20, 2024 #3 it just a trunk number 10002. Attachments IMG_3615.png 248.4 KB · Views: 11
SteveITS 3CX MVP Silver Partner Advanced Certified Joined Jun 20, 2018 Messages 4,474 Reaction score 2,189 Jul 20, 2024 #4 What is its max calls set to?
SkyArmy Bronze Partner Joined Jul 20, 2024 Messages 5 Reaction score 0 Jul 20, 2024 #5 Hello i didn't get it ? :
SteveITS 3CX MVP Silver Partner Advanced Certified Joined Jun 20, 2018 Messages 4,474 Reaction score 2,189 Jul 20, 2024 #6 The trunk should have a setting for the max number of calls for that trunk. Reactions: jed
SkyArmy Bronze Partner Joined Jul 20, 2024 Messages 5 Reaction score 0 Jul 20, 2024 #7 So how can i get this setting ?
jed Platinum Partner Advanced Certified Joined Feb 1, 2010 Messages 577 Reaction score 394 Jul 20, 2024 #8 The Setting is below your SIP Trunk --> Options However, you should set this to the amount of lines you have on the actual SIP Trunk (ask your Provider). If it is a GSM Gateway, they typically have 1, 2, 4, or 6 SIM Cards, and then you need to set the SIM Calls accordingly. Reactions: Evolute IT
NicholasP_3CX Support Team 3CX Support Premier Customer Advanced Certified Joined Apr 25, 2014 Messages 2,487 Reaction score 2,357 Jul 22, 2024 #9 Also, the default is 10. If you have only 1 SIM card for example, you will NOT be able to use more than 1 call on this gateway. Reactions: jed
SkyArmy Bronze Partner Joined Jul 20, 2024 Messages 5 Reaction score 0 Jul 22, 2024 #10 Hello thanks for reply, I just let you know that there are 2 SIM cards on gateway Device I am confirmed there is no issue with my Gateway device. It is with 3cx that what i am no getting.
