NTP client on 3CX v20 on Debian 12
Alain.R.
I try to configure NTP on a 3CX v20 on Debian 12. I just run the command timedatectl status and I get :
System clock synchronized: no
NTP service: n/a
how to proceed ?
thanks
Alain Rime
It's weird actually, cos I've been having a problem with the NTP client on a debian install with the ISO and i've just had to resolve manually.
Code:
sudo nano /etc/ntp.conf
stick your NTP server in there "server uk.pool.ntp.org" for example
save it out.
Code:
sudo systemctl enable ntp
sudo systemctl restart ntp
I tried the command :
I get the error :
Failed to enable unit: Unit file ntp.service does not exist.
I have installed this 3CX v20 from the official ISO : https://downloads-global.3cx.com/downloads/debian12iso/debian-amd64-netinst-3cx.iso
I have the version Version 20.0 Update 1 (Build 731 Release).
I also check on another system that I installed in v20, same issue.
Best Regards,
Alain
Code:
sudo apt-get update sudo apt-get install ntp
I installed it and use the following command:
I get :
Failed to enable unit: Refusing to operate on alias name or linked unit file: ntp.service
try sudo systemctl enable ntp.service
Still an error :
I also observe that there is no /etc/ntp.conf but only /etc/ntpsec/ntp.conf
So it seems that your repository is not installing ntp but ntpsec.
Could you provide more info about the exact procedure to configure it ?
Thanks.
ntp out of the box seems to be working fine! Its nftables that is the issue!
add udp 123 to the /etc/nftables.conf file.
I just included it into the existing 3cx udp ports! (in bold below!)
# 3CX PhoneSystem specific
tcp dport { 80,443,5000,5001,5015,5060,5061,5062,5090 } ct state new counter accept comment "Accept 3CX PhoneSystem TCP ports"
udp dport { 69,123,5060,5090,7000-10999 } counter accept comment "Accept 3CX PhoneSystem UDP ports"
The ntp conf that pertains to above!
# By default, exchange time with everybody, but don't allow configuration.
restrict default kod nomodify nopeer noquery limited
Urs_S4A
