Nutanix AHV Install
Michael Adamson
Trainee Partner
Hi, has anyone been able to install 3CX on Nutanix AHV?
During the install, I'm met with the error to advise it cannot connect to the internet. My guess is that the Debian installer does not have the Nutanix Nic drivers. Is anyone able to advise how to overcome this?
Thanks, Mike
This isn't a 3CX question. If you insist on trying to install 3CX on an unsupported platform then you'll want to do a manual installation using this guide: https://www.3cx.com/docs/manual/installing-debian-linux-pbx/
For the NIC driver part you'll want to try the Nutanix or Debian forums to see about installing Debian on Nutanix.
Reactions: N_G
Hi Michael,
I have installed many 3cx's on my AHV Cluster.
I have not noticed this issue. I downloaded the iso from 3cx.com and uploaded to my AHV Images, From there, just add 1 NIC to the VM and install, as usual, no issues.
Are you sure its not a networking issue rather than a Virtual Machine issue? If your esc back after that error are you able to set a static IP on the VM? Can you see the NIC?
K7oR0x
