- Joined
- Jun 20, 2018
- Messages
- 4,480
- Reaction score
- 2,192
We set up a client 6 months ago. They tell me this week that 2-3 weeks ago they started having audio problems to one particular company, that of course they call a lot:
"For some reason when we call (other company) sometimes the calls are very muffled—almost like we are in a tunnel. The issue goes both ways—they can’t hear us and we can’t hear them.
They can call us right back and the call is fine and have never had the issue when they call us—only when we call them.
You can usually tell when the problem is going to occur because when you make the call it rings a couple times normally and then makes a deep ringing sound and that is when problem happens.
This does not happen every time we call them—just periodically."
"Also, when you dial the number there is a period of silence before it starts ringing and this is different from calling other numbers."
I am not sure what to do with that report? We installed hotfix 2 to 16 update 5 on Aug. 10, around when this reportedly started, and update 6 last night, which didn't help. To me though this seems more like a codec issue but why only one direction and why occasional (though some there say it is frequent)? Could the other end be using different codecs for incoming and outgoing, and how can I figure that out, as that would be at the SIP trunk level right? I didn't try restarting the phones or SBC (nudge for remote restart) but I can't see how those would affect calls to one number.
Phone codecs: PCMU, PCMA, G722
codecs for external calls: PCMU, G729, GSM, G722, PCMA, OPUS
- 3CX Version, Pro Annual 16.0.641
- Server OS, Debian 9
- Is the 3CX Server Hosted and where? In our data center, under KVM
- IP Phone Make/Model/Firmware Yealink T42S
- Provisioning Method: SBC
- Trunk Provider GreenLink
- Has the Firewall Checker passed: YES
- Are custom Phone Templates being used: NO
