Office 365 Integration Template Missing
digital4
I've been away from 3CX for a while and just set up a new 15.5 SP6 PBX Pro. Everything went smooth except I cannot find the Office 365 Integration. By following the instructions on the 3CX site I go to Settings> CRM Integration> Server Side - and there is no Office 365 in the dropdown list. There are several other templates in the list and all Available CRM Integrations are up to date. This is a Pro version and the license is active. All PBX updates are installed as well. Any suggestions?
For server side integration, this is configured from the Contacts section in the 3CX Console, please check this:
https://www.3cx.com/docs/manual/pbx-crm-integration/#h.5q3i8vyk3vdt
You also have the client side approach, to synchronize personal contacts, from 3CXPhone for Windows > Settings > Import Contacts.
Kind regards.
No, that's been deprecated.
Ok, I'll give it a try
I think there are many deprecated articles still active. Would be good to have them either removed or at least marked as no longer current. I have gone around in circles myself a few times.
a.
Yes, many articles have been removed, but it seems there are still a few in our site, we will get on this. Thanks for the feedback.
costionofrei
