Office Hours / Inbound Rules are off
blarkin
Hi.. I have set our office hours properly (settings=>Language & Office Hours) and also set a holiday rule. When configuring the Inbound rules, Destination for calls during office hours doesn't seem to be working, but only the Afterhours destination. I have checked our Time zone etc.. and seems to be correct (as well as office hours).
Have you ensured that the PBX is not forced to Out Of Office hours?
By default the dial code is *64, if this have not be changed dial *640 to force the PBX to use the default office hours and then check again.
Thanks for your reply.. I did as you suggested and the recording said now using default office hours, but the issue still remains. I have set my office hours (Eastern Standard Time) from 7:30am - 6pm (Mon - Fri). My rules are simple.. during office hours route to a Ring Group, after office hours route IVR. Not sure how to troubleshoot this. I have on On-Prem install, the Debian server has the correct date/time. Thanks for any further help! - Bill
Do you have multiple DID's or just the main trunk number?
I have multiple DIDs. I tried creating an inbound rule on the main trunk number which did not work at all. I appreciate your time.
I would suggest that you contact with your partner to check as it might require to open a support ticket to check this further.
OK, thank you for your help. - Bill
Reactions: TheodorosG_3CX
You are welcome ;)
mazet
