Other ringtone for special numbers
Kurt2
We have some public numbers. Let's say 111111111, 222222222 and 333333333.
They are defined on our incoming siptrunk.
And they are routed via an incoming rule to an extension.
Is it possible to have a different ringtone for each number?
So calling 111111111 comes in and gives the default ringtone on my Yealink T46S.
Calling to 222222222 comes in and should give another ringtone on my yealink T46S.
Calling to 333333333 comes in and should give a different ringtone than the other 2 on my Yealink T46S.
I know there is a different sound for incoming calls from external and internal but that is not the issue.
Is that possible?
Kind regards
Kurt
I'm afraid it's not possible to specify ringtones per DID. That said, do bear in mind that ring tones can be different per call type depending on the situation (External, Internal, Queue call, etc).
If what you want is to be able to distinguish between what DID was dialed, what you can do is use a different name for the DID/Inbound Rules and then go to "3CX MC >> Advanced >> Contacts >> Options" and enable the prepend/append to CID option. That way, you'll get the DID's Rule corresponding name in the caller ID for those calls.
ARKC
