Out bound Contact center functionalities
Quest4Voice
I am being met with these demands in my New call center i a pointer to such features will help in my PoC. Under covid am being asked for loads of services...
can we dial multiple calls to the customer simultaneously for a pre-recorded message
are we be able to do automated surveys using questionnaire and collect feedback on customer service
Is there support for inbound and outbound blending.
The ability to tag the customer as blacklisted should be supported i have seen this on phones trying to register though.
Is there a way for Dialer have the capability of fetching the contacts for dialing based on the defined priority and weightage of the leads
Is there a way for Dialers to have the capability of fetching the contacts for dialing based on the phone pattern from the leads
Can a Dialer have the capability of fetching the contacts for dialing in the same sequential order as mentioned in the leads
can we integrate with third party applications and automate the call list upload process for dialing
the capability of studying the behaviour of individual customers and then decides the best time to initiate the call. It should be intelligent enough to identify best time to call a person after multiple attempts to a number by considering all previous attempts and not only the last attempt.
Most, if not all of these would probably require some sort of add-on. I'm sure that there are 3CX users on the forum, that make use some of these features (or similar), and can offer a link. Some of your desires may require more of an explanation.
We have two dialers: "Power Dialer" and "Preview Dialer". These could be modified to meet your needs, but a lot more information about your requirements would be needed. We also have a survey tool "Survey Creator"
abctel2
