Out of Office Switch Indicator
kat
Hi there,
We have set up dial codes to Force 3CX Phone System to IN or OUT of office and that is working fine, however would like to know if there is anyway to show the phones being switched on to IN or OUT of office.
Hello @kat
You know that this dial code is to turn ALL the system to IN or OUT ?
If you're using *80 to do it, *801 put on IN, *802 put on OUT and *80 is to check what is the current state
this dial code is not for a daily use , this is for special use, for example you are normally closed on weekend , and sometimes you want to work, you can force pbx to be in with this dial code.
if you need to switch from in to out automaticly you can use hours settings in PBX
Thanks for the response. Just want to confirm that there is no visual indication that the system is IN or OUT?
No, there is not one yet but it's a much requested feature so it might be coming soon. We never know!
Reactions: kat
Wecare_ITA
